Monopoly Go Stickers Sunshine Express is a fun and competitive event where players advance by earning Express Coins. The key to progressing through the levels is to accumulate as many Express Coins as possible, which can only be earned through daily tournaments. Understanding how to maximize your coin earnings and manage your resources effectively will help you climb the leaderboard faster.
Earning Express Coins and Ranking
The only way to advance in Sunshine Express is by participating in daily tournaments and earning Express Coins based on your leaderboard rank. The better your final position, the more Express Coins you receive. Higher ranks yield more coins, so it's important to perform well each day.
One effective tip is to save your dice for rounds with high multipliers, especially when approaching the Railway tile on the board. The Railway tile is linked to big point events like Shutdown and Bank Robbery, which can boost your score significantly. By carefully managing your dice and using them strategically during these moments, you increase your points and improve your leaderboard position.
Accumulating Coins Over Time
Express Coins accumulate over the course of Monopoly Go buy Stickers the season. If you don't reach the next level on a given day, your coins will roll over and add to the next day's total. This rollover system makes it easier to advance over time without feeling pressured to perform perfectly every single day.
MMOexp:Unlocking New Levels in Monopoly GO Sunshine Express
Florencehg63
