Nex, the Ancient Summoner, stands as one of RuneScape’s most iconic and challenging boss fights. Located deep within the God Wars Dungeon, Nex tests your combat skills, reflexes, and RuneScape gold teamwork like few others. Whether you’re venturing into this battle solo or with a group, mastering Nex will grant you access to some of the game’s most rewarding loot and a truly epic experience.
This guide breaks down the essential strategies, gear recommendations, and tactics you’ll need to conquer Nex’s wrath and emerge victorious.
Who is Nex? Understanding the Boss and the Battle
Nex is a powerful Zarosian general who commands formidable forces within the God Wars Dungeon. The fight itself is divided into four distinct phases, each introducing new mechanics, minions, and attack patterns. Recognizing these phases and adapting quickly is key to success.
Essential Preparation: Gear and Supplies
Being properly equipped is crucial when facing Nex’s deadly powers. Below are recommendations to help you maximize your damage while staying alive.
Recommended Gear
Weapons: High damage melee weapons like the Abyssal Bludgeon or Noxious Scythe work best.
Armor: Choose heavy-hitting defensive gear such as Torva for melee users or Seasinger for magic users.
Accessories: Equip offensive amulets like the Amulet of Torture, and rings such as the Ring of Vigour or an imbued Berserker ring.
Boots & Cape: Prioritize boots like Primordial boots and capes like the Fire cape or Infernal cape to boost survivability and damage.
Inventory Essentials
Stat-boosting potions like Super Combat potions.
Healing items such as Sharks, Rocktails, and Saradomin brews.
Prayer renewal potions to maintain your protection prayers.
Utility items such as Antifire potions and Stamina potions.
Weapon poisons or bleed-inducing items for extra damage over time.
Breaking Down Nex’s Four Phases
Each phase introduces unique threats and requires different tactics.
Phase 1: Smoke Phase
In this phase, Nex creates hazardous smoke clouds that explode on contact. You must avoid standing inside these clouds while dealing damage from a safe distance. Watch for the Smoke Tendrils attack and maneuver accordingly to minimize damage.
Phase 2: Shadow Phase
Nex summons shadow minions that sap your stats, making the fight more dangerous. Quick elimination of these minions is crucial. Keep an eye on your status and counteract with anti-poison and stat-boosting prayers.
Phase 3: Blood Phase
This phase emphasizes Nex’s healing through blood tendrils, which players must sever promptly. Avoid blood pools that can trap you and coordinate with teammates to efficiently cut tendrils and prevent Nex from regenerating health.
Phase 4: Ice Phase
The final phase sees Nex using freezing attacks that immobilize players. Destroy the Ice Tendrils quickly to free trapped allies and use freedom abilities to break immobilization. Nex’s aggression increases here, so staying alert is critical.
Combat Strategies and Tips
Prayer and Defensive Abilities
Use Protect from Melee against Nex’s melee strikes.
Switch prayers between Protect from Magic or Protect from Ranged depending on her current attack style.
Offensive prayers like Piety or Augury boost your damage output.
Employ debuffs such as Debilitate to reduce the damage Nex deals.
Use freedom abilities to escape tendrils and immobilizing effects.
Movement and Positioning
Constant movement helps you avoid smoke, blood, shadow, and ice hazards.
Use safe spots to maximize your DPS while minimizing risk.
Stay aware of tendrils and pools, moving swiftly to prevent damage or status effects.
Team Roles and Communication
In group fights, assigning roles such as tendril cutters, damage dealers, and healers improves efficiency. Clear communication about tendril status and phase changes keeps everyone coordinated and alive.
Rewards and Why Nex is Worth It
Defeating Nex grants access to some of RuneScape’s most sought-after items, including:
Zaryte bow
Various pieces of Torva, Pernix, and Virtus armor
Unique Nex drops with high value and powerful stats
These rewards make the demanding fight worthwhile and pave the way for even greater challenges.
Final Thoughts
Nex, the Ancient Summoner, is a thrilling and demanding boss that pushes your RuneScape skills to the limit. With the right preparation, understanding of mechanics, and teamwork, you can overcome her wrath and claim the treasures she guards.
Step into the God Wars Dungeon with confidence, master each phase, and buy RuneScape gold prove yourself worthy of Nex’s legendary rewards!
RSgoldfast RuneScape: The Rise and Wrath of Nex
