How to Catch or Buy Bunnelby in Pokémon Legends: Z-A
Napsal: sob říj 25, 2025 9:23
If you're hunting for the energetic and adorable Bunnelby in Pokémon Legends: Z-A, you're in the right place. Whether you're aiming to catch it in the wild or prefer to buy one, this guide will walk you through both methods. Bunnelby, with its quick movements and determined nature, is a great addition to any trainer's team. Let’s break down how you can add this Pokémon to your roster in the game.
Where to Find Bunnelby in Pokémon Legends: Z-A
Bunnelby can be found in the wild, though its specific location depends on the region you’re exploring. Generally, Bunnelby tends to appear in grassy areas, so be sure to look in places with dense vegetation. Keep an eye out for patches of tall grass in open fields or rural areas, where it often pops up. If you're unsure, check your map for locations marked with active Pokémon spawns, as these often correlate with areas where Bunnelby can be found.
You can increase your chances of encountering a Bunnelby by traveling during the day. It’s known to be more active in daylight hours, so early morning or mid-afternoon are the best times to spot it. If you're lucky, Bunnelby may even appear in groups, giving you an opportunity to catch multiple.
Buying Bunnelby in Pokémon Legends: Z-A
If you're looking for a quicker method and don't want to spend hours searching, you can always buy Bunnelby through the in-game marketplace. Many players trade Pokémon through the community or exchange them at specific locations within the game, and sometimes Bunnelby can be purchased directly from NPCs or other players.
Buying a Pokémon like Bunnelby comes in handy if you're looking for a specific nature, stats, or moveset. It's also a good option if you don't have time to search for one yourself but want to get it for a specific purpose, like completing a Pokédex entry or evolving it.
Tips for Catching Bunnelby
When you encounter a Bunnelby in the wild, use caution. Although it’s not the hardest Pokémon to catch, it does tend to flee quickly if you're not careful. Try using a status-inducing move like Sleep or Paralysis to slow it down and make it easier to catch. A Quick Ball or Dusk Ball can be particularly effective if you’re trying to catch it early in the battle.
For those aiming to evolve their Bunnelby into its next form, ensure you catch it with enough time to train it to level up. Bunnelby evolves into Diggersby at level 20, so it’s well worth the effort to level it up quickly. If you’re training in the wild, use Exp. Candies to accelerate the process and avoid wasting time on unnecessary battles.
Building a Team with Bunnelby
Once you’ve caught or bought your Bunnelby, consider its role in your team. Bunnelby is a Normal/Ground-type Pokémon, which gives it a unique set of strengths and weaknesses. It’s particularly strong against Electric-types, but watch out for Water-types, as they have the upper hand against Ground-type Pokémon. Make sure to build a balanced team around it, ideally pairing it with Pokémon that can cover its weaknesses.
Getting a Bunnelby in Pokémon Legends: Z-A is a relatively straightforward process whether you choose to catch it in the wild or buy it. With its unique typing and useful abilities, Bunnelby can be a valuable member of your team if trained well. Just remember to keep an eye out for its habitat in grassy areas, and don’t forget to plan ahead if you’re aiming for a quick catch or a trade with other players.
