Crafting endgame accessory in Path of Exile depends on one simple fact: the abject item’s ilvl controls which top-tier modifiers can appear. If you appetite T1 life, attenuate access mods, or the accomplished alembic rolls, you charge the appropriate abject ilvl. That agency planning your map runs and targeting sources that anxiously advance Item levels aloft the accustomed map bead caps PoE 1 Currency.
Start at the top with Tier 16 maps. High-tier maps accord the accomplished accustomed bead levels, so you should run the best maps you can bright fast and consistently. In general, map monster Level determines the ilvl of items they drop, with abracadabra and attenuate monsters abacus 1 and 2 to that abject respectively. Rolling your T16 maps with High abundance and pack-size modifiers raises your absolute bead volume, which increases your adventitious of seeing the rare, high-ilvl bases you want.
Use specific mechanics that accession ilvl aloft the map baseline. Incursion (Temple of Atzoatl) is one of the best options because the Temple’s different boodle tables and instance mechanics tend to aftermath items at college able levels than the map you use to run them. That makes the Temple a able ambition if you hunt ilvl 86 bases for top-end crafting. Likewise, strongboxes can backpack modifiers that addition the Level or affection of the items inside; assertive box modifiers accession the independent accolade Level abundant that, back commutual with a T16 area, they can advance abject ilvl into the aristocratic range. Plan your runs so you hit temples and high-value strongbox zones back possible.
Bring scarabs and body accoutrement to accession your odds. Ambush-type scarabs add added strongboxes to a map, which multiplies your affairs to acquisition a high-ilvl box with advantageous modifiers. Other scarabs (Divinity, Adversary, Nemesis variants) access monster quantity, rarity, or appropriate spawns, and that college body anon translates into added attenuate drops and added opportunities for top-tier bases. Use scarabs selectively on maps you can bright bound so you aerate ilvl crop per hour.
Treat farming as an investment: spend currency to scale your returns. Running the actual map pool, affairs scarabs, rolling maps for quantity, and absorption on Temple or strongbox routes all amount u4gm PoE 1 Currency up front. You should plan a bend that balances amount and return: buy the maps and accoutrement that accord the best ilvl allowance for your time. If you appetite to advance for ilvl 88-level tech, advance in Ambush-heavy runs and targeted strongbox searches; if you charge abiding ilvl 86 bases, circle Temple runs and bang-up farms while befitting an eye on barter windows. PoE 1 Currency fuels the aeon that brings you the mirror-tier crafting options you crave.
Put it calm into a repeatable loop. Pick 2–4 map types that you bright bound and that abutment the mechanics above. Add scarabs or map accessory modifiers back the amount makes sense. Prioritize temple routes and strongbox-dense maps for ilvl-chasing runs, and aperture in bang-up farms on canicule back you can anxiously bottomward them. Track amount on barter sites so you advertise or accumulate bases based on accepted demand. With a abiding accepted you will about-face map time and Currency into the high-ilvl foundations that alleviate accurate endgame crafting.
U4GM Shares Where to Farm High Item Level Bases in PoE 3.26
Smsnaker235
