Stránka 1 z 1
MMOexp Borderlands 4: Entering Dominion City
Napsal: pát zář 26, 2025 8:28
od Stellaol
Once you grapple across, you'll stumble upon the wreckage of Callis' ship - a callback to an earlier mission. Explore the wreckage until you find a small room with Borderlands 4 Money a red button. Press it, and the eastern door will open, granting you your first entry into Carcadia District, the outermost part of Dominion City.
From the shipwreck, push deeper into the district. The terrain becomes increasingly unstable, with tilted buildings and large chunks of debris forming your path forward. Early on, you'll notice a slanted metal beam on your right. Climb it carefully until you reach a wind boost vent that launches you into the air. While airborne, grab the grapple point on the left wall to keep advancing.
The path here is mostly linear, so keep climbing, grappling, and dashing as necessary. Eventually, you'll drop into a hidden cave system. This cave serves as your gateway to Dominion proper and unlocks your first Fast Travel Station in the region: Final Defiance.
At this point, the NPC Levaine will contact you. After listening to her briefing, follow the rock slide eastward, pushing deeper into the Carcadia District. Keep your bearings steady - your destination is a fortified zone called The Lockaway, and it's here that your investigation will continue.
Finding The Lockaway
As you approach The Lockaway, the district becomes more hostile. Expect tougher enemy resistance, including Dominion shock troops equipped with shields and energy rifles. Use cover smartly, and remember to loot as you go - ammo gets chewed through quickly in these tight corridors.
Upon reaching The Lockaway, you'll notice that it doesn't immediately appear to function as a safehouse. Instead, it feels more like an abandoned archive. To activate it, you'll need to locate a hidden item and then power up the facility.
Locating the Lockaway Datapad
Step inside The Lockaway and face the northwest wall. Here you'll see a massive mural of the Timekeeper, painted in Dominion's signature gold-and-black palette. This mural isn't just for show - it hides a grapple point. Fire your grappling hook and pull yourself upward.
Once you're on the ledge, follow the staircase and then grapple again to climb higher. At the top, search the area carefully. On a small table pressed against the north wall, you'll find a glowing Data Pad. This is the key Borderlands 4 Items you need to activate The Lockaway and secure it as a safehouse.
Opening the Safehouse
With the Data Pad in your possession, head back down to the main floor. Opposite the Golden Chest in the central chamber, you'll spot a command console. Insert the Data Pad here to bring The Lockaway online.
As the systems hum to life, the facility transforms into buy Borderlands 4 Money a fully operational Safehouse. This gives you access to new vending machines, storage, and a reliable checkpoint within Dominion City. Finally, speak to Levaine through your comms to complete the objective.
