Stránka 1 z 1
Can I fax documents at a UPS store?
Napsal: pát zář 13, 2024 6:56
od Gray Xandria
I need to send some important documents via fax and I've heard that UPS stores offer faxing services. How can I use these services, what are the typical costs, and what should I do if there isn’t a UPS store in my vicinity?
Re: Can I fax documents at a UPS store?
Napsal: pát zář 13, 2024 7:15
od ParkerMegan
Yes, you can fax documents at a UPS store. The process is simple: just bring your documents to the store, and the staff will help you send them. The cost varies depending on the number of pages and the fax's destination. If you don’t have a UPS store nearby or want more detailed information, check out this guide: https://comfax.com/fax-at-ups/. It compares prices and lists the best alternatives.
