Stránka 1 z 1
U4GM PoE 3.27 Graft and Implant Gear Power Guide
Napsal: pon lis 10, 2025 9:24
od jch6
In Path of Exile’s 3.27 Necropolis League, there’s a whole new way to shape your gear that feels far more hands-on than anything before. It’s all built around a corpse crafting system, where you use the spirits of monsters you’ve taken down to fuel your creations. Out in the maps, you’ll run into Allflame Embers – these let you tweak monster packs so they’re infused with special spirits. When those packs fall, their corpses hold unique modifiers you can collect and later use. That’s where PoE PC Currency comes into play for many players, as managing resources alongside these corpses can make or break your crafting plans.
Once you’ve taken down an Ember-infused pack, you’ll spot the haunted corpses they leave behind. With an item called Unresolved Anguish, you can scoop them up into your inventory. Each corpse is basically a container for one or more guaranteed modifiers – these are called Grafts.
The higher the level of the monster, the better the potential outcome when you finally craft. You’ll haul your collection to the Necropolis, bury them in graves, and arrange them so their effects stack in the way you want. When you’re ready, Arimor the Undertaker runs an exorcism, burning through those corpses and their Grafts to spit out one rare item. The item’s level is based on the average corpse level you’ve used, so farming high-level monsters is a smart move if you’re chasing endgame gear.
The real fun starts when you begin mixing and matching Grafts to lock in the stats you’re after. Say you’re building a weapon for raw physical damage – you’d go for corpses that give flat added physical damage, percentage boosts, and maybe attack speed. If you’re after spell power, you might combine “+1 to all spell skill gems” with increased cast speed and critical strike chance. Some Grafts aren’t just stat boosts – they can trigger special crafting outcomes, like fracturing a mod so it’s permanent or even mirroring the item. These effects can be game-changing if you’re chasing perfect rolls. Planning ahead is key, and you’ll quickly learn which monster types tend to drop the corpses with the right kind of Grafts for your build.
Because the whole thing is deterministic – you’re not just gambling with random rolls – it’s possible to aim for exactly what you need. That said, it’s still a grind. You’ll spend time in maps hunting the right corpses, juggling inventory space, and deciding which ones are worth keeping. And since some of the best corpses come from tougher fights, you’ll need to balance survival with farming efficiency. For many players, pairing corpse crafting with smart resource management, including when to PoE Currency, is the way to get the most out of the Necropolis League’s new system.
