The overclock type you can apply depends on Core Modules, which drop from certain enemies and bosses. Each gun brand has its own flavour. Jakobs’ Precision Modules hit harder on crits and tighten accuracy, but they kick like a mule and punish missed shots. Maliwan’s Elemental Modules make status effects brutal and frequent, but they heat your gun up fast. Tediore’s Efficiency Modules are all about utility – shorter reloads, bigger throw damage – though they do not give the same raw DPS boost as others. Picking the right module is half the battle, and it often comes down to your playstyle more than pure stats.
Not every gun is worth the investment. Legendary weapons tend to have a hidden efficiency edge, building less Thermal Stress per shot, which makes them prime candidates for heavy overclocking. Check the weapon’s details before spending your hard-earned cores. A flashy purple might look tempting, but if it overheats in seconds, it will just slow you down. Also, think about how your character build supports your weapon choice. Skills that cool weapons faster, reload quicker, or bleed
Gear synergy is where overclocking really shines. Anointments can make or break a setup – something like “On Action Skill End, vent 50% Thermal Stress” can keep a Maliwan blaster running almost non-stop. The same goes for class skills; a Siren who controls crowds can afford to run hotter weapons, while a Gunner might trigger heat dumps when activating their Action Skill. Play around with different setups until you find one that clicks. Overclocking is not about maxing every stat – it is about keeping your gun firing when it matters most. Nail that balance, and you will tear through Mayhem levels and raid bosses like they are nothing. And if you want to push your build further, having a stash of Borderlands 4 Items for sale can make the grind a whole lot easier.
