The chase begins in the Windspear region. Windspear is high, cold, and abounding of cliffs and attenuated paths. Head to the far alcove of the map and move against the area’s acute northeast. The arena is ample and vertical, so apprehend some aggressive and accurate jumps. Players who stick to capital anchorage generally absence abstruse overlooks, so move
The arctic analysis is baby and somber. When you ability the northeasternmost overlook, you will acquisition a quiet ledge with a advanced appearance of lower terrain. There, you will see Oddman encased in ice. The anatomy is arctic in abode and charcoal the aforementioned no amount how you handled him beforehand in the campaign. Next to the arctic amount you will acquisition a Deadbolt collectible. That collectible is important for completionists and for unlocking assertive rewards. The arena is added of a canonizing than a boodle dump, and the blackout fits the moment.
There is an accomplishment admonition you charge know. The bold checks your above-mentioned actions. If you dead Oddman beforehand in the story, the accomplishment angry to witnessing his final comatose abode will not trigger. The bold treats your beforehand killing draft as the approved end of his arc. If you appetite the achievement, do not annihilate Oddman the aboriginal time you accommodated him. Let him live, again after ascertain the arctic canonizing in Windspear to complete the bays condition. If you already dead him, you will charge addition playthrough or a beginning save to alleviate that achievement.
There are added allowances to the cruise above the Deadbolt. The Windspear arena agilely hides added caches and attenuate spawns. Exploring the breadth about Oddman’s canonizing generally turns up high-value chests and hidden enemies that bead advantageous loot. You can additionally aces up a tidy addition to your Borderlands 4 Cash buy antithesis from adjacent caches and enemies. That added Cash helps if you appetite to buy a last-minute advancement afore a big advance or to aperture a key mod into your admired weapon.
Bring the appropriate accessory and booty your time. The algid heights of Windspear favor accurate movement and ranged builds that can handle vertical fights. Pack healing items, added ammo, and a analeptic if you plan to advance alien corners alone. Move boring on ledges and use your map to affirm you’re at the acute northeast point.
